What is Valuekeep Integrator?
Valuekeep
Integrator recommends a conceptual model of data integration and consequent
functional logic between systems. As a solution for integration between systems,
Valuekeep Integrator brings together a set of characteristics which are
considered fundamental in products in this area.
- Flexibility:
it is a solution capable of integrating different systems or services in a
synchronized and cooperative way, i.e. defining which processes should be
shared or made available between different systems or services. It has the
capacity to support the addition of new systems and services due to the
comprehensiveness of its architecture, without creating ruptures with the
control systems and process logic.
- Reuse:
allows the reuse of functions in integration projects, reducing development
costs and implementation times. A structured integration should lead to an
environment where existing business functions are easily shared and reused with
minimal effort. Each service should be flexible enough to support new business
models as they emerge. This is, achieved in this integration solution by
separating the integration management rules (supported by the Valuekeep
Integrator platform) and the business rules of the different systems (supported
by the different plugins).
- Simplification:
integrating different software applications and different platforms requires a
sophisticated technical solution. This integration solution is capable of
working with different hardware systems, different operating systems and
different applications.
- Scalability:
experience shows that after the implementation of an integration solution, new
modules or functions to be integrated are identified. The architecture of this integration solution
ensures that the availability of execution is equal to or greater than the
availability of the systems that already existed before the integration. The
availability challenge grows with the volume of transactions and number of
integrated systems and/or services. This integration solution is capable of
growing according to the increasing demands of sustaining the organization.
- Security:
ensures the management and control of access between the different systems and
services that use the integration framework.
- Data
Transformation and Mapping: this service integration solution has the ability
to easily define bi-directional data transformations from its native
representation to other formats more suitable for process integration, for
example: JSON.
- Scalability:
An integration infrastructure can be compared to a constantly evolving entity
as it seeks to develop and expand its business. The objective of this
integration platform is to enable the expansion of business processes with the
inclusion of various proprietary or third-party plugins.
Valuekeep Integrator is an integration platform that is only available for subscription under the UNIVERSE plan.
How to set up the Valuekeep Integrator?
The Valuekeep Integrator can be installed using the following options: · Portal (link): download the Valuekeep Integrator addon setup available and install it; · PRIMAVERA Deployment Center: this option is only available for customers that subscribed ...
How to subscribe to Valuekeep Integrator?
The use of the Valuekeep Integrator platform requires a subscription to the addon with the same name. The subscription request should be requested to your partner developer.
How does the Valuekeep Integrator work?
Valuekeep Integrator is a generic and abstract platform to implement any data or system integration scenario (across different technologies). The abstraction is represented by the concept of pipeline and consists of the decomposition of a complex ...
What is the Valuekeep Integrator-SDK?
Valuekeep Integrator - SDK provides a Security wizard (available in the installation folder) that provides cryptographic services, including secure encryption and decryption of data, which allows encryption of keys, namely passwords that must be ...
What is the Valuekeep-Integrator architecture?
The VALUEKEEP V3 - Valuekeep Integrator plugin, provides in its installation folder: <Install Path> <VKKPlugin\SAMPLES\CONFIGS, an integration solution (VK3_V10_Integration.config), that can be reused as a base example, which can be customized ...
