What is the default workflow of the requests?
By
default, the requests workflow has the following states:
State
| Notes
New | Initial
state, SLA start.
Allows to create WOs
in the states New or In Progress. |
In Progress | Changes the state of the
associated requests to In Progress. |
Completed | End of SLA. |
Closed | Final
state, end of SLA.
Change the WO state
to Closed. |
Canceled | Final
state, end of SLA.
the associated requests to Canceled. |
The
following scheme shows how to process transitions between states:
What is the default contract workflow?
By default, the contract workflow has the following states: State Notes New Initial state. Approved Canceled Final state. Closed Final state. The following scheme shows how to process transitions between states:
How to set up the contract workflow?
The state flow for contracts can be changed to be in line with the organization's working method. To create or change the configurations for a new state, you must access Settings | Contracts | Workflow; 1. The state list is presented; 2. To create ...
How to see the list "All Requests"?
The "All Requests" list allows the request manager to access all the requests he created and the asset requests on his access levels. To view the list "All Requests" on the menu select the option "Requests | All Requests" or search for "All ...
What is the default workflow of the work orders?
By default, the work orders workflow has the following states: State Notes New Initial state, SLA start. In Progress Changes the state of the associated requests to In Progress. Completed End of SLA. Changes the state of the associated requests to ...
What is the default requisitions workflow?
By default, the requisition workflow has the following states: State Notes New Initial state. Approved Allows to record costs. Canceled Final state Closed Final state. The following scheme shows how to process transitions between states:
