What is the default requisitions workflow?
By default,
the requisition workflow has the following states:
State
| Notes
New
| Initial state. |
Approved | Allows to record costs. |
Canceled
| Final state |
Closed
| Final state.
The
following scheme shows how to process transitions between states:
How to view the requisitions workflow?
You can change the flow of states for requests to ensure that they match the organization's way of working. To create or change the settings for a status, follow these steps: Access Settings | Requisitions | Workflow; Click on Create or select an ...
What is the default contract workflow?
By default, the contract workflow has the following states: State Notes New Initial state. Approved Canceled Final state. Closed Final state. The following scheme shows how to process transitions between states:
How to set up the contract workflow?
The state flow for contracts can be changed to be in line with the organization's working method. To create or change the configurations for a new state, you must access Settings | Contracts | Workflow; 1. The state list is presented; 2. To create ...
How do I create requisitions?
Using the requisitions, the employees in an organization can request parts to maintenance. To create a requisition, follow these steps: Go to Requisitions | Requisitions; Click on Create; Fill in the necessary fields. Click on Save and New. ...
What is the default workflow of the work orders?
By default, the work orders workflow has the following states: State Notes New Initial state, SLA start. In Progress Changes the state of the associated requests to In Progress. Completed End of SLA. Changes the state of the associated requests to ...
