What is the default contract workflow?
By default, the contract workflow has the
following states:
State
Notes
New
Initial state.
Approved
Canceled
Final state.
Closed
Final state.
The following scheme shows how to process
transitions between states:
How to set up the contract workflow?
The state flow for contracts can be changed to be in line with the organization's working method. To create or change the configurations for a new state, you must access Settings | Contracts | Workflow; 1. The state list is presented; 2. To create ...
How to create a contract type?
To create a new Contract Type, select the option Settings | Contracts | Contract Types: The list Contract Types will be displayed; Press the "Create" button; When creating and editing Contract Types, you must consider: i.The first Contract Type to be ...
What is the default requisitions workflow?
By default, the requisition workflow has the following states: State Notes New Initial state. Approved Allows to record costs. Canceled Final state Closed Final state. The following scheme shows how to process transitions between states:
How to view the list of contract types?
The Contract Types list allows you to view all contract types. To view Contract Types list on the menu, select the option Settings | Contracts | Contract Types or search "Contract Types". The Contract Types list has the following criteria: It is only ...
How to view the state transitions of a contract?
A contract is created in the initial state and until it is finished, it goes through different states. The administrator has the chance to view all the states the contract went through. For the administrator to view the contract states, select the ...
