WebApi - Pipeline Hashing Calculation
Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been integrated or if it  suffered any change in the data, requesting a new integration. This hashing technique is applicable to an information segment (hashset), that is, it allows to identify the attributes that make up the hashing key (by ignoring integration requests when the entity suffers changes in attributes that are not a part of the key composition).
This method allows to calculate the pipeline hash, that is, to calculate the hashing of the records that must be considered in an integration pipeline. Internally, after getting the hash, the integration solution confronts this value with the previous one and, if they differ, it considers that the record must be synchronized again.
The method used for that is: POST /api/mytenant/myorganization/integration/pipelines/calchash
Before using the method, it is necessary to create in each Entity being synchronized, three custom attributes. Next, we show an example:
  1. custom_SourceHash: attribute that saves the data source hashing key, must be of the type "short text".
  2. custom_TargetHash: attribute that saves the data target hashing key, must be of the type "short text".
  3. custom_IsSync: attribute that validates if the record will be integrated, must be of the type "Boolean".
An example (Json), of the data structure for the calculation of a pipeline hashing.
1.      {
  "Algorithm": "MD5",
  "BaseEntity": "BusinessCore.Brands",
  "LyncEntities": "BusinessCore.Brands JOIN BusinessCore.BrandModels ON BusinessCore.Brands.Id = BusinessCore.BrandModels.BrandId",
  "Attributes": "BusinessCore.Brands.BrandKey, BusinessCore.Brands.Description, BusinessCore.BrandModels.ModelKey, BusinessCore.BrandModels.Description as ModelDescription",
  "Filter": "",
  "FieldSourceHash": "custom_SourceHash",
  "FieldTargetHash": "custom_TargetHash",
  "FieldIsSync": "custom_IsSync"
Description of the attributes available on the request:
  1. Algorithm: identifies the hashing algorithm, when ignored, the system assumes: MD5;
  2. BaseEntity: identifies the base entity (main table);
  3. LyncEntities: identifies the related entities, when ignored, the system assumes its own base entity;
  4. Attributes: identifies the attributes that make up the hashing key (that is, the segment used for the hash calculation);
  5. Filter: identifies the conditional filter to be applied for the hash calculation;
  6. FieldSourceHash: identifies the SourceHash attribute, when ignored, the system assumes: custom_SourceHash. This attribute will be used to preserve the calculated value;
  7. FieldTargetHash: identifies the TargetHash attribute, when ignored, the system assumes: custom_TargetHash;
  8. FieldSyncHash: identifies the IsSync attribute, when ignored, the system assumes: custom_IsSync. This attribute will be used to control if the record is synchronized (the records are classified for synchronization when the attribute value FieldSourceHash is different from the attribute value FieldTargetHash).
When this method is executed successfully, it returns a Json data structure for the hashing key attributes inserted in "Attributes".
    • WebApi - Pipeline Hashing Synchronization
      Valuekeep Integrator adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been integrated or if it  suffered ...
    • Plugin V10 – Pipelines – Hashing
      The plugin PRIMAVERA V10 – Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been ...
    • How to set up the pipeline execution (Windows Service)?
      The host is the process runtime than instantiates the Valuekeep Integrator engine (PipelineEngine) to manage the pipeline execution (using a scheduling procedure or using a specific on-demand context). The platform provides a Windows Service ...
    • How does the pipeline versioning work?
      The VALUEKEEP V3 - Valuekeep Integrator plugin adopts a versioning control based on a hashing system. Each pipeline has a versioning control, that is, it has a hashing key that allows identifying if the subset of information (hashset) has not yet ...
    • WebApi - Auditing Pipeline
      The Valuekeep Integrator conceptually allows to monitor the execution of all pipelines. This feature allows the implementing agent/integrator to control the execution of integration flows and identify irregular situations that require to eventually ...
