WebAPI - How to get the list of asset attachments regarding a work order?
This method allows, in a simplified way, to obtain the list of attachments of the assets referring to a work order.
The method to be used when getting the list is:
GET  url/api/mytenant/myorganization/maintenance/workorders/getWorkordersAttachementsAssets
When this method is executed successfully, it returns HttpStatusCode.200OK.
        "name""AUD-SUB_0000007368_20221121_092616245.pdf",
        "size"381428.000000,
        "sizeDecimalPlaces"null,
        "mediaType""application/pdf",
        "workOrderId""b4fa6c64-9670-ed11-a81b-000d3ac29e92",
        "path""801769/801769-0001/maintenance/workOrders/b4fa6c64-9670-ed11-a81b-000d3ac29e92/attachment?fileName=0000007368_20221121_092616245.pdf&index=0"
This method allows you to list asset attachments according to the filled parameters:
i.assignedTo: Person to whom the work order is assigned.
ii.company: The company's key.
modifiedOn: Gets the attachments after the inserted date.
