WebAPI – Get work orders and technicians from workshops the authenticated user is responsible for
This method returns the list of work orders and technicians that belong to the workshops the authenticated user is responsible for.
The methods to be used to get the list are:
- GET /api/mytenant/myorganization/maintenance/planners/getplanneritems?start=2019-03-01&end=2019-04-01
- GET /api/mytenant/myorganization/maintenance/planners/getplanneritems?start=2019-03-01&end=2019-04-01&maxRecords=100
- GET /api/mytenant/myorganization/maintenance/planners/getplanneritems?start=2019-03-01&end=2019-04-01&stateKey=003WORKORDER;004&workShopKey=MN;OT&technicianKey=0006;0007
The method gets the start and end date to filter the Work Orders by expected date.
If the parameter maxRecords is not specified, it returns a maximum of 100 records. The parameters stateKey, workShopKey and technicianKey are optional and allow to define a list of values separated by “;”. The logic is the following:
- stateKey: returns all WOs with these states
- workShopKey: returns all WOs and employees from these workshops.
- technicianKey: returns all WOs assigned to these technicians, and in the employee list return only these.
The server returns a response HttpStatusCode.OK, with the work orders and the technicians, with an expected date between the start and end dates, the technicians assigned to the WOs and all technicians from the workshops of the authenticated user with the corresponding workshops and specialties.
If the parameter maxRecords is specified and the value is inferior to 100, it returns the number of records. If the parameter value is higher than 100, it returns an error message.
The WO state description is returned in the language selected by the user.
WebAPI – How do I get work orders assigned to user?
This method returns the work orders list assigned to each employee of a specific company. The method to be used to get the work orders list assigned to the employee is: GET ...
WebAPI – Get Work Orders assigned to the employee
This method returns the work orders list assigned to each employee of a specific company. The method to be used to get the work orders list assigned to the employee is: ...
WebAPI – How do I create work orders?
This method offers a simple way of creating a Work Order for a specific Asset, Location, Tool or Route. The method to be used to create a work order is: POST /api/mytenant/myorganization/maintenance/workorders/newWorkOrderInfo Json example to create ...
WebAPI - How does the OAUTH 2.0 authorization work?
OAuth 2.0 is a standard authorization protocol that allows applications to access a user's account in a web service (HTTP) such as the Valuekeep CMMS Web API. The protocol delegates user authentication to the service that holds the user's account and ...
WebAPI - How to get the locations an employee has access to?
The method returns the location list and the access level the employee has access to. The method to be used to get the location list and the access level the employee has access to is: GET ...
