Webapi - Deleting a work order consumption report
This
method allows you to delete a work order consumption report.
The method
used to delete a work order consumption report is:
DELETE
url/api/mytenant/myorganization/maintenance/workorderreportconsumptions/{{companyKey}}/{{workorderreportconsumptionKey}}
The
parameters being replaced on the method are:
- companyKey:
The company key
- modelKey: The key of the
consumption report you wish to delete.
When this
method is executed successfully, it returns HttpStatusCode.204.
WebAPI – How do I update the material consumption report?
This method allows to change a material consumption. The method to be used when changing the work order material consumption ...
Webapi - Creating a consumption report in a work order
This method allows you to create a consumption report in a work order in a simplified way. The method used to create a consumption report in a work order is: POST {{url}}/api/{{tenant}}/{{organization}}/maintenance/workOrderReportConsumptions ...
Webapi - Deleting a work order labor report
This method allows you to delete a work order labor report. The method used to delete a work order labor report is: DELETE url/api/mytenant/myorganization/maintenance/workorderreportlabors/{{companyKey}}/{{workorderreportlaborKey}} The parameters ...
WebAPI - Creating a follow-up report in a work order
This method allows you to create a follow-up report in a work order in a simplified way. The method used to create a follow-up report in a work order is: POST ...
WebAPI - Deleting a Work Order
This method allows you to delete a work order. The method to use for deleting a work order is: DELETE url/api/mytenant/myorganization/maintenance/workorders/{{companyKey}}/{{workorderKey}} The parameters to be overridden in the method are: ...
