Webapi - Deleting a task
This method allows you to delete a task.
The method to be used when deleting a task is:
DELETE  url/api/mytenant/myorganization/maintenancecore/activities/{{taskKey}}
The parameters being replaced on the method are:
taskKey: key of the task you wish to delete.
When this method is executed successfully, it returns HttpStatusCode.204.
    • WebAPI – How do I update the task verification record?
      This method allows you to change the task verification record of a work order. The method to be used for changing the work order task verification record is: POST /api/mytenant/myorganization/maintenance/ ...
    • WebAPI - Deleting a requisition
      This method allows you to delete a requisition. The method to be used when deleting a requisition is: DELETE  url/api/mytenant/myorganization/requisitions/requisitions/{{company}}/{{requisitionKey}} The parameters being replaced on the method are: ...
    • WebAPI - Deleting a brand
      This method allows you to delete a brand. The method to be used when deleting a brand is:  DELETE  url/api/mytenant/myorganization/businesscore/brands/{{brandKey}}  The parameters being replaced on the method are: {{brandKey}}: key of the brand you ...
    • WebAPI - Deleting a type of task verification
      This method allows you to delete a task verification type.   The method to be used to delete a type of task verification is:  DELETE  url/api/mytenant/myorganization/maintenancecore/verificationtypes/{{verificationTypeKey}}  The parameters being ...
    • WebAPI – How do I update the material consumption report?
       This method allows to change a material consumption. The method to be used when changing the work order material consumption ...
