WebAPI - Deleting a model
This method allows you to change a model.
The method to be used when deleting a model:
DELETE  url/api/mytenant/myorganization/businesscore/brandmodels/{{modelKey}}
The parameters being replaced on the method are:
  1. modelKey: key of the model you wish to delete.
When this method is executed successfully, it returns HttpStatusCode.204.
    • WebAPI - Deleting a requisition
      This method allows you to delete a requisition. The method to be used when deleting a requisition is: DELETE  url/api/mytenant/myorganization/requisitions/requisitions/{{company}}/{{requisitionKey}} The parameters being replaced on the method are: ...
    • WebAPI - Deleting a brand
      This method allows you to delete a brand. The method to be used when deleting a brand is:  DELETE  url/api/mytenant/myorganization/businesscore/brands/{{brandKey}}  The parameters being replaced on the method are: {{brandKey}}: key of the brand you ...
    • WebAPI - Creating a model
      This method allows to create a model in a simplified manner. The method to be used when creating a model: POST url/api/mytenant/myorganization/businesscore/brandmodels  Json example for creating a model:  1.     {         "modelKey": "ASP", ...
    • WebAPI - Record and Maintenance of Parts and Services
      This method allows to manage the record and maintenance of parts and services. For the inventory (parts), besides recording the part, it is also possible to classify it in terms of inventory, by identifying: the default warehouse, the minimum and ...
    • WebAPI - Creating an equipment
      This method allows to create an equipment in a simplified manner. The method to be used when creating an equipment: POST url/api/mytenant/myorganization/assetmanagementcore/equipmentItems Json example for creating an equipment: 1.       { ...
