Webapi - Deleting a misc cost type
This
method allows you to delete a misc cost type.
The method
to be used when deleting a misc cost type is:
DELETE
url/api/mytenant/myorganization/maintenancecore/misccoststypes/{{companyKey}}/{{misccoststypeKey}}
The
parameters being replaced on the method are:
- companyKey: Company key.
- misccoststypeKey:
The key of the misc cost type you wish to delete.
When this
method is executed successfully, it returns HttpStatusCode.204.
This method allows you to delete a misc cost. The method to be used when deleting a misc cost is: DELETE url/api/mytenant/myorganization/maintenancecore/misccosts/{{misccostKey}} The parameters being replaced on the method are: misccostKey: ...
Webapi - Creating a misc cost type
This method allows to create a misc cost type in a simplified manner. The method to be used when creating a type of misc cost is: POST url/api/mytenant/myorganization/maintenancecore/misccoststypes Json example for creating a type of misc cost: ...
WebAPI – How to update the misc costs report?
This method allows you to change the misc cost of a work order. The method to be used for changing one other cost is: POST /api/mytenant/myorganization/maintenance/workorderreportmisccosts / ...
This method allows to create a misc cost in a simplified manner. The method to be used when creating a misc cost is: POST url/api/mytenant/myorganization/maintenancecore/misccosts Json example for creating a misc cost: { ...
Webapi - Creating a misc cost report in a work order
This method allows you to create a misc cost report in a work order in a simplified way. The method used to create a misc cost report in a work order is: POST {{url}}/api/{{tenant}}/{{organization}}/maintenance/workOrderReportmisccosts Json example ...
