Webapi - Deleting a maintenance plan
This
method allows you to delete a maintenance plan.
The method
to be used when deleting a maintenance plan is:
DELETE
url/api/mytenant/myorganization/maintenancecore/maintenanceplans/{{maintenanceplanKey}}
The
parameters being replaced on the method are:
- maintenanceplanKey: key of
the maintenance plan you wish to delete.
When this
method is executed successfully, it returns HttpStatusCode.204.
Webapi - Creating a maintenance plan
This method allows to create a maintenance plan in a simplified manner. The method to be used when creating a maintenance plan is: POST url/api/mytenant/myorganization/maintenancecore/maintenanceplans Json example for creating a maintenance plan: ...
WebAPI – How do I create work orders?
This method offers a simple way of creating a Work Order for a specific Asset, Location, Tool or Route. The method to be used to create a work order is: POST /api/mytenant/myorganization/maintenance/workorders/newWorkOrderInfo Json example to create ...
WebAPI – How do I update the task verification record?
This method allows you to change the task verification record of a work order. The method to be used for changing the work order task verification record is: POST /api/mytenant/myorganization/maintenance/ ...
WebAPI – How do I update the material consumption report?
This method allows to change a material consumption. The method to be used when changing the work order material consumption ...
WebAPI – How to update the misc costs report?
This method allows you to change the misc cost of a work order. The method to be used for changing one other cost is: POST /api/mytenant/myorganization/maintenance/workorderreportmisccosts / ...
