WebAPI - Deleting a brand
This
method allows you to delete a brand.The
method to be used when deleting a brand is:
DELETE
url/api/mytenant/myorganization/businesscore/brands/{{brandKey}}
The
parameters being replaced on the method are:
- {{brandKey}}: key
of the brand you wish to delete.
When
this method is executed successfully, it returns HttpStatusCode.204.
WebAPI - Deleting a requisition
This method allows you to delete a requisition. The method to be used when deleting a requisition is: DELETE url/api/mytenant/myorganization/requisitions/requisitions/{{company}}/{{requisitionKey}} The parameters being replaced on the method are: ...
WebAPI - Deleting the request
This method allows you to delete a request. The method to be used when deleting a request: DELETE url/api/mytenant/myorganization/requests/requests/{{companyKey}}/{{RequestKey}} The parameters being replaced on the method are: companyKey: company ...
WebAPI - Deleting a location
This method allows you to delete a location. The method to be used when deleting a location is: DELETE url/api/mytenant/myorganization/assetmanagementcore/locations/{{companyKey}}/{{locationKey}} The parameters being replaced on the method are: ...
WebAPI - Deleting a tool
This method allows you to delete a tool. The method to be used when deleting a tool is: DELETE url/api/mytenant/myorganization/assetmanagementcore/equipmentItems/{{companyKey}}/{{toolKey}} The parameters being replaced on the method are: companyKey: ...
Webapi - Deleting a task
This method allows you to delete a task. The method to be used when deleting a task is: DELETE url/api/mytenant/myorganization/maintenancecore/activities/{{taskKey}} The parameters being replaced on the method are: taskKey: key of the task you wish ...
