Webapi - Creating a unit
This method allows to create a unit in a simplified manner.
 The method to be used when creating a unit is:
POST url/api/mytenant/myorganization/corepatterns/units
 Json example for creating a unit:
  1. {
            "unitKey""HR",
            "description""Hora",
            "precisionDigits"2,
            "conversionFactor"1.0,
            "symbol""HR",
            "isDimensionBaseUnit"false,
            "dimension""01"
This method allows to create a unit according to the parameters filled in:
  1. unitKey: The key of the unit. Mandatory field.
  2. description: Short description of the unit. This field is mandatory.
  3. precisionDigits: Number of decimal places.
  4. conversionFactor: Conversion factor.
  5. symbol: Symbol.
  6. isDimensionBaseUnit: Dimension base unit. Fill in this field with true or false. There can only exist one unit with this field active (true).
  7. dimension: Dimension. (01-Quantity; 02- Weight; 03-Time; 04-Length). Mandatory field.
When this method is executed successfully, it returns HttpStatusCode.201Created.
    • WebAPI - Creating a warehouse
    • WebAPI - Creating a request
    • WebAPI - Creating a requisition type
      This method allows creating a type of requisition in a simplified manner. The method to be used to create a requisition type is: POST url/api/mytenant/myorganization/requisitionscore/requisitiontypes Json example for creating a type of requisition:  ...
    • WebAPI - Creating a tool
      This method allows to create a tool in a simplified manner. The method to be used when creating a tool is: POST url/api/mytenant/myorganization/assetmanagementcore/equipmentItems Json example for creating a tool: 1.     {     "equipmentKey": "PCR", ...
    • WebAPI - Creating an equipment
      This method allows to create an equipment in a simplified manner. The method to be used when creating an equipment: POST url/api/mytenant/myorganization/assetmanagementcore/equipmentItems Json example for creating an equipment: 1.       { ...
