WebAPI - Creating a requisition type
This method allows to create a type of requisition in a simplified manner.
The method to be used to create a requisition type is:
POSTurl/api/mytenant/myorganization/requisitionscore/requisitiontypes
Json example for creating a type of requisition:
"requisitionTypeKey": "PI",
"description": "Pedido Interno",
"isDefault": false,
"remarks": "pedido de material"
This method allows to create a type of requisition according to the parameters filled in:
- requestTypeKey: The requisition type key. Mandatory field.
- description: Short description of the requisition type. This field is mandatory.
- isDefault: Fill in with true or false. A default type is mandatory and only one configured default type can exist.
- remarks: Remarks.
When this method is executed successfully, it returnsHttpStatusCode.OK.
This method allows creating a type of requisition in a simplified manner. The method to be used to create a requisition type is: POST url/api/mytenant/myorganization/requisitionscore/requisitiontypes Json example for creating a type of requisition: ...
WebAPI - Creating a request
Webapi - How to create a part of the service type?
This method allows to create a part of the service type in a simplified manner. The method to be used to create a part of the service type is: POST url/api/mytenant/myorganization/businesscore/parts Json example to create a part of the service type: ...
WebAPI - Creating a warehouse
WebAPI - Deleting a requisition type
This method allows you to delete a requisition type. The method to be used when deleting a requisition type is: DELETE url/api/mytenant/myorganization/requisitionscore/requisitiontypes/{{requisitionTypeKey}} The parameters being replaced on the ...
