WebAPI - Creating a monitoring value
This method allows to create a monitoring value in a simplified manner.
The method to be used when creating a monitoring value:
POST url/api/mytenant/myorganization/assetmanagement/monitoringvalues
Json example for creating a monitoring value:
1.     {
        "monitoringValueKey""000001",
        "value"911.000000,
        "date""2021-07-21T12:50:21+01:00",
        "remarks"null,
        "monitoring""0001",
        "assetType"2,
        "equipment""ATC01",
        "location"null,
        "tool"null,
        "workOrder""OT00008",
        "company""DEMO"
This method allows to create a monitoring value according to the parameters filled in:
MonitoringValueKey: The monitoring value key. If this parameter is not filled in, it assumes the defined sequential number.
Value: The monitoring value you wish to record. This field is mandatory.
Date: The monitoring value record date. This field is mandatory.
Remarks: Remarks.
Monitoring: The key of the monitoring whose value you wish to record. This field is mandatory.
AssetType: Asset type. (1- Location. 2- Equipment. 3- Tool.) Mandatory field.
Equipment: The equipment key..
Tool: The tool's key.
WorkOrder: The key of the work order whose monitoring value you wish to record.
Company: The company's key.
When this method is executed successfully, it returns HttpStatusCode.OK.
    • WebAPI - Creating a Monitoring
      This method allows to create a monitoring in a simplified manner. The method to be used when creating a monitoring: POST url/api/mytenant/myorganization/assetmanagementcore/monitorings Json example for creating a monitoring:  { ...
    • WebAPI - Creating a warehouse
    • WebAPI - Creating a request
    • WebAPI - Creating a tool
      This method allows to create a tool in a simplified manner. The method to be used when creating a tool is: POST url/api/mytenant/myorganization/assetmanagementcore/equipmentItems Json example for creating a tool: 1.     {     "equipmentKey": "PCR", ...
    • WebAPI - Creating an equipment
      This method allows to create an equipment in a simplified manner. The method to be used when creating an equipment: POST url/api/mytenant/myorganization/assetmanagementcore/equipmentItems Json example for creating an equipment: 1.       { ...
