Webapi - Creating a misc cost type
This method allows to create a misc cost type in a simplified manner.
The method to be used when creating a type of misc cost is:
POST url/api/mytenant/myorganization/maintenancecore/misccoststypes
Json example for creating a type of misc cost:
  1.       {
            "miscCostTypeKey""JANTAR",
            "description""Jantar",
            "maxValue": {
                "amount"100.00,
                "fractionDigits"2,
                "symbol""€"
            "minValue": {
                "amount"12.00,
                "fractionDigits"2,
                "symbol""€"
            "defaultValue": {
                "amount"25.00,
                "fractionDigits"2,
                "symbol""€"
            "remarks"null,
            "miscCost""Refeiçoes",
            "currency""EUR",
            "company""DEMO"
This method allows to create a type of misc cost according to the parameters filled in:
  1. misccostTypeKey: The misc cost type key. This field is mandatory.
  2. description: Short description of the misc cost type. This field is mandatory.
  3. maxValue: Maximum value.
  4. minValue: Minimum value.
  5. defaultValue: Default value.
  6. remarks: Remarks.
  7. miscCost: The misc cost key. This field is mandatory.
  8. currency: The currency's key. This field is mandatory.
  9. company: The company's key. This field is mandatory.
When this method is executed successfully, it returns HttpStatusCode.201Created.
    • WebAPI - Creating a request
    • Webapi - Creating a misc cost
      This method allows to create a misc cost in a simplified manner.  The method to be used when creating a misc cost is:   POST url/api/mytenant/myorganization/maintenancecore/misccosts  Json example for creating a misc cost: { ...
    • Webapi - Deleting a misc cost type
      This method allows you to delete a misc cost type.  The method to be used when deleting a misc cost type is:   DELETE  url/api/mytenant/myorganization/maintenancecore/misccoststypes/{{companyKey}}/{{misccoststypeKey}} The parameters being replaced on ...
    • WebAPI - Creating a requisition type
      This method allows creating a type of requisition in a simplified manner. The method to be used to create a requisition type is: POST url/api/mytenant/myorganization/requisitionscore/requisitiontypes Json example for creating a type of requisition:  ...
    • Webapi - Creating a misc cost report in a work order
      This method allows you to create a misc cost report in a work order in a simplified way. The method used to create a misc cost report in a work order is: POST {{url}}/api/{{tenant}}/{{organization}}/maintenance/workOrderReportmisccosts Json example ...
