Webapi - Creating a maintenance plan
This method allows to create a maintenance plan in a simplified
manner.
The method to be used when creating a maintenance plan is:
POST
url/api/mytenant/myorganization/maintenancecore/maintenanceplans
Json example for creating a maintenance plan:
"maintenancePlanKey": "PM_0001",
"description": "Verificação tubos de água ",
"remarks": null,
"maintenancePlanType": "CR",
"maintenancePlanTasks": [
"task": "T_000001",
"duration": "01:00:00"
"workshop": "MN"
This method allows to create a maintenance plan according to the
parameters filled in:
- maintenancePlanKey: The maintenance plan key. This field is
mandatory.
- description: Short description of the maintenance plan. This field
is mandatory.
- remarks: Remarks.
- maintenancePlanType: The key of the maintenance plan type. This
field is mandatory.
- maintenancePlanTasks. The task key for the maintenance plan and its
duration. This field must have at least one task.
- workshop: The key of the workshop.
When this method is executed successfully, it returns
HttpStatusCode.201Created.
WebAPI - Creating a warehouse
WebAPI - Creating a request
WebAPI – How do I create work orders?
This method offers a simple way of creating a Work Order for a specific Asset, Location, Tool or Route. The method to be used to create a work order is: POST /api/mytenant/myorganization/maintenance/workorders/newWorkOrderInfo Json example to create ...
Webapi - Deleting a maintenance plan
This method allows you to delete a maintenance plan. The method to be used when deleting a maintenance plan is: DELETE url/api/mytenant/myorganization/maintenancecore/maintenanceplans/{{maintenanceplanKey}} The parameters being replaced on the ...
WebAPI – How do I update the task verification record?
This method allows you to change the task verification record of a work order. The method to be used for changing the work order task verification record is: POST /api/mytenant/myorganization/maintenance/ ...
