WebAPI - Creating a failure cause
This
method allows to create a failure cause in a simplified manner.
The
method to be used when creating a failure cause:
POST
url/api/mytenant/myorganization/maintenancecore/failurecauses
Json
example for creating a failure cause:
"failureCauseKey": "C05",
"description": "Falha de energia",
"remarks": null,
"failureCauseActions": [
"failureAction": "A01"
"failureAction": "A02"
This
method allows to create a failure cause to the parameters filled in:- failureCauseKey: The
failure cause's key. Mandatory field.
- description:
Short description of the failure cause. This field is mandatory.
- remarks:
Remarks.
- failureCauseActions:
In these parameters, we must associate the different failure actions. This way,
in each failureAction, we place the failure action key.
When
this method is executed successfully, it returns HttpStatusCode.OK.
WebAPI - Creating a warehouse
WebAPI - Creating a request
Webapi - Creating a failure symptom
This method allows to create a failure symptom in a simplified manner. The method to be used when creating a failure symptom is: POST url/api/mytenant/myorganization/maintenancecore/failuresymptoms Json example for creating a failure symptom: { ...
Webapi - Deleting a failure cause
This method allows to delete a failure cause in a simplified manner. The method to be used when deleting a failure cause is: DELETE url/api/mytenant/myorganization/maintenancecore/failurecauses/{{failureCauseKey}} The parameters being replaced ...
This method allows to create a failure in a simplified manner. The method to be used when creating a failure is: POST url/api/mytenant/myorganization/maintenancecore/failures Json example for creating a failure: { "failureKey": "001", ...
