WebAPI - Creating a failure action
This method allows to create a failure action in a simplified manner.
The method to be used when creating a failure action:
 POST url/api/mytenant/myorganization/maintenancecore/failureactions
 Json example for creating a failure action:
1.        {
        "failureActionKey""A06",
        "description""Verificar painel eléctrico",
        "remarks"null
This method allows to create a failure action according to the parameters filled in:
  1. failureActionKey: The failure action's key. Mandatory field.
  2. description: Short description of the failure action. This field is mandatory.
  3. remarks: Remarks.
When this method is executed successfully, it returns HttpStatusCode.OK.
    • WebAPI - Creating a warehouse
    • WebAPI - Creating a request
    • WebAPI - Creating a failure cause
      This method allows to create a failure cause in a simplified manner. The method to be used when creating a failure cause: POST url/api/mytenant/myorganization/maintenancecore/failurecauses Json example for creating a failure cause:  1.          { ...
    • Webapi - Deleting a failure action
      This method allows to delete a failure action in a simplified manner. The method to be used when deleting a failure action is: DELETE  url/api/mytenant/myorganization/maintenance/failureactions/{{failureActionKey}}  The parameters being replaced on ...
    • Webapi - Creating a failure
      This method allows to create a failure in a simplified manner.  The method to be used when creating a failure is:   POST url/api/mytenant/myorganization/maintenancecore/failures  Json example for creating a failure: {         "failureKey": "001", ...
