WebAPI- Changing the state of the request
This method allows to change the state of a
request.
The method to be used when changing the
state of a request:
PUT {{url}/api/{{tenant}}/{{organization}}/requests/requests/{{companyKey}}/{{requestKey}}/schemaEntityState
The parameters on the method are the
following:- companyKey: company key
- requestKey: key of the request you wish to
change states
Json example to change the request state:
Simply place the request state key you wish
to change.
Example: You wish to change the request
state "in progress" to the state "finished". In the json,
you must put the state key of the finished request state.
To view the request state keys, access:
Menu -> Settings -> Requests -> Work Flow.
When this method is executed successfully,
it returns HttpStatusCode.200 OK
WebAPI - Creating a request
WebAPI – Changing a Request state and the service classification
This method allows to change the request state and, if it is on the final state, it allows to classify the service. The method to be used when changing the state of a request: POST ...
WebAPI – How can I change the work order state?
This method allows you to change a work order state. The method to be used for changing the work order change is: Post {{url}/api/{{tenant}}/{{organization}}/maintenance/workorders/changeSchemaEntityState/{{companyKey}} The parameters in the method ...
WebAPI - Changing the request attribute
This method allows to change a request field. The method to be used when changing the request attribute: PUT {{url}/api/{{tenant}}/{{organization}}/requests/requests/{{companyKey}}/{{requestKey}}/{{atributo}} The parameters on the method are the ...
WebAPI - Changing a requisition attribute
This method allows changing a requisition. The method to be used when changing a requisition attribute is: PUT {{url}/api/{{tenant}}/{{organization}}/requisitions/requisitions/{{company}}/{{requisitionKey}}/{{atributo}} The parameters on the method ...
