WebAPI - Changing a requisition type attribute
This method allows to change a requisition type.
The method to be used when changing a requisition type attribute is:
PUT {{url}/api/{{tenant}}/{{organization}}/requisitionscore/requisitiontypes/{{requisitiontypeKey}}/{{atributo}}
The parameters on the method are the following:
- requisitionTypeKey:requisition type key
- atributo: to be replaced by the attribute you wish to change on the requisition type
WebAPI - Changing a requisition attribute
This method allows changing a requisition. The method to be used when changing a requisition attribute is: PUT {{url}/api/{{tenant}}/{{organization}}/requisitions/requisitions/{{company}}/{{requisitionKey}}/{{atributo}} The parameters on the method ...
WebAPI - Creating a requisition type
This method allows creating a type of requisition in a simplified manner. The method to be used to create a requisition type is: POST url/api/mytenant/myorganization/requisitionscore/requisitiontypes Json example for creating a type of requisition: ...
WebAPI - Changing a part or service attribute
This method allows to change a part or service field. The method to be used to change a part or service attribute is: PUT {{url}/api/{{tenant}}/{{organization}}/businesscore/parts/{{partKey}}/{{atributo}} The parameters on the method are the ...
WebAPI - Changing the request attribute
This method allows to change a request field. The method to be used when changing the request attribute: PUT {{url}/api/{{tenant}}/{{organization}}/requests/requests/{{companyKey}}/{{requestKey}}/{{atributo}} The parameters on the method are the ...
This method allows to create a type of requisition in a simplified manner. The method to be used to create a requisition type is: POSTurl/api/mytenant/myorganization/requisitionscore/requisitiontypes Json example for creating a type of requisition: ...
