WebAPI - Changing a requisition attribute
This method allows changing a requisition.
The method to be used when changing a
requisition attribute is:
PUT
{{url}/api/{{tenant}}/{{organization}}/requisitions/requisitions/{{company}}/{{requisitionKey}}/{{atributo}}
The parameters on the method are the following:
i.company: company key
ii.requisitionKey: requisition key
iii.attribute: to be replaced by the attribute you
wish to change on the requisition
Body example to change the requisition attribute:
Select:
i.x-www-form-urlencoded
ii.on the column VALUE, place the value of the
attribute you wish to change.
WebAPI - Changing a requisition type attribute
This method allows to change a requisition type. The method to be used when changing a requisition type attribute is: PUT {{url}/api/{{tenant}}/{{organization}}/requisitionscore/requisitiontypes/{{requisitiontypeKey}}/{{atributo}} The parameters on ...
WebAPI - Deleting a requisition
This method allows you to delete a requisition. The method to be used when deleting a requisition is: DELETE url/api/mytenant/myorganization/requisitions/requisitions/{{company}}/{{requisitionKey}} The parameters being replaced on the method are: ...
WebAPI - How to get the list of requisitions?
This method allows getting the list of requisitions in a simplified manner. The method to be used when getting the requisitions list is: GET url/api/mytenant/myorganization/requisitions/requisitions When this method is executed successfully, it ...
WebAPI - How to get the list of requisition types?
This method allows to get the list of requisition types in a simplified manner. The method to be used when getting the list of requisition types is: GET url/api/mytenant/myorganization/requisitionscore/requisitiontypes When this method is executed ...
WebAPI - Changing the request attribute
This method allows to change a request field. The method to be used when changing the request attribute: PUT {{url}/api/{{tenant}}/{{organization}}/requests/requests/{{companyKey}}/{{requestKey}}/{{atributo}} The parameters on the method are the ...
