How to view the labor list?
The Labor list allows the maintenance manager to analyze the records associated with a work order. You can access this list under Work | Explore Costs | Labor or by searching for Labor in the search available in the header.
This list is organized based on the following criteria:
- By default, only the labor for the current quarter is shown.
- It is sorted in descending order of the expected date of the work order.
To help analyze the data, a search is available within the list itself.
By default, the Work Order, Description filter is selected, but you can change it.
You can also access the work order display screen directly from the list.
Labor records can be made via work orders.
How to view preventive labor?
The preventive labor list allows you to have an overview of the employees and their specialties of the preventive plans tasks, as well as the corresponding planned and reported times. To consult the list in the menu, select the Work | Explore Work | ...
How do I consult the Labor List?
Through the Labor list, the maintenance manager can verify all the associated labor logs. To consult the Labor list, simply go to Work | Explore Costs | Labor or search for Labor. This list is only available for the Administrator and Work Manager ...
How to view the work orders?
The administrator has a list where it is possible to view all his work orders. To view the list, on the menu select the option Work | Work Orders. The list has the following criteria: It is only available for the administrator role. The list is ...
How to create a work order?
