How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to
view the existent parts stock in each warehouse.
To view the list, select the option "Parts and
Inventory | Explore | Parts Stock" or search "Parts Stock".
The Parts Stock list has the following criteria:
- It
is only available for the administrator role.
- It
is ordered in ascending order of parts date.
- From
the list it is possible to access the part and the warehouse view screen.
- It
is possible to search the list using the search box and by selecting the
field to be searched on the 3 dots.
- You
can filter the list by parts, warehouses, stock higher than the maximum
defined and stock lower than the minimum defined.
- If
the stock is below the minimum, it is presented in red.
- It
is possible to see on the list whether the warehouse is managed
externally.
How do I import parts entry?
The parts entries in stock can be fed from individual records or through batch records by importing .csv files. To load batch parts entries, select the option Definitions | General | File Import or using the parts entries list ( Parts and Inventory | ...
How to import parts?
The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
How to import spare parts?
The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
How to view spare parts by asset?
The spare parts list allows to have an overview of the pieces used, where they are used and the quantities needed. To view the list, on the menu select the option Assets | Explore | Spare Parts or search Spare Parts. The spare parts list has the ...
