What is the default workflow of the work orders?
By default, the work orders workflow has the following states:
State
Notes
New
Initial state, SLA start.
In Progress
Changes the state of the associated requests to In Progress.
Completed
End of SLA.
Changes the state of the associated requests to Completed.
Closed
Final state, end of SLA.
Canceled
Changes the state of the associated requests to Canceled.
On Hold
The following scheme shows how to process transitions between states:
    • What is the default contract workflow?
      By default, the contract workflow has the following states: State Notes New Initial state. Approved Canceled Final state. Closed Final state. The following scheme shows how to process transitions between states:
    • How to configure the work order workflow?
      The state flow for work orders can be changed to be in line with the organization's working method. To create or change the new state configurations, you must access Definitions | Work | Workflow  The state list is presented; To create new states, ...
    • How do I create the work order type?
      Work order types allow you to classify the work orders and to apply specific behaviors after being configured. To create a new work order type, select the Definitions | Work | Work Order Types option: The list of work order types is presented; Press ...
    • How to view the traceability of the work order?
      It is possible to view the entity originated in a work order. The work order traceability list allows the maintenance manager to view if the work order originated in a request or in a preventive maintenance event, or if it was created individually. ...
    • How to report labor associated with the work order?
