What is the workflow of the preventive maintenances?
The preventive workflow has the following states:
State
Notes
New
Initial state.
Allows changes
Approved
Does not allow changes.
Create the preventive mainentance events.
Closed
Final state.
Replaced
Final state.
Previous versions' internal state for the preventive.
Canceled
Final state.
The following scheme shows how to process transitions between states:
    • How does preventive maintenance rescheduling work?
      The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
    • How to create a preventive maintenance?
      Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
    • What is preventive maintenances batch management?
      Preventive maintenances management was designed to allow you to simultaneously change the state, delete or create new versions for a set of preventive maintenances. For that, you must access Work | Preventive Maintenance | Preventive Maintenance ...
    • How to create a new version of the preventive maintenance?
      Creating new versions allows you to improve preventive maintenance by reusing the current configuration. To create a version, access Work | Preventive Maintenances; The list of preventive maintenances will be displayed; Select the preventive ...
    • How to join plans on the preventive maintenance?
      When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
