How can I see the list of parent device changes?
With the profile of Administrator, you can see the list of parent device changes of the assets.
This list is available at Assets | Explore | Parent Device Changes with the following specifics:
- Only available for the Administrator.
- From the list, you can access the asset display screen.
How do I register a change of Parent Device on the devices?
To register a change of parent device on a device, follow these steps: Go to Assets | Devices; Select the device for which you want to register the change of Parent Device; Click on the button Operations and then, on Change Parent Device; The list of ...
How can I see the list of location changes?
The location changes list allows the administrator to view the asset location changes. To view the list, select the option "Assets | Explore | Location Changes". The location changes list follows these criteria: It is only available for the ...
How do I record parent location change on the locations?
To record a parent location change in a location, select the option Assets | Locations. The list of locations is presented Select the location you wish to record the Parent location change to and press the button "View" On the "Operations" link, ...
How to see the list of failures?
From the Work Order it is possible to record asset failures. The failure list allows the maintenance manager to see asset failures by work order. To see the menu list select the option "Work | Explore | Failures". The failure list follows these ...
How can I see the Costs dashboard?
The dashboard Costs shows metrics and indicators related to the recording of costs in work orders. To access this dashboard, click on the icon Applications in the top left corner of the header, and then on the option Analytics. A tab will open with ...
