How do I see the list of parts entries?
The parts entry list allows the administrator to view the parts entry.
To view the list, select the option "Parts and Inventory | Explore | Parts Entry".
The parts entry list follows these criteria:
  1. It is only available for the administrator role.
  2. By default, only the parts entry whose expected date is on the current quarter will be presented.
  3. From the list it is possible to access the warehouse view screen.
    • How to record a stock parts entry?
      The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
    • How to see the list of parts issue?
      To view the list, select the option "Parts and Inventory | Explore | Parts Issue". The parts issue list follows these criteria:  It is only available for the administrator role. By default, only the parts issue whose expected date is on the current ...
    • How to report/delete a stock parts issue?
      The stock parts issue is always associated to a warehouse, it is not possible in a single part issue to place several warehouses. To issue a part, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish to ...
    • How do I create parts?
      Items can be used in the maintenance plans for forecasting needs and/or in the material consumption report after being created. To create an item, select the option Parts and Inventory | Parts: The parts list is presented Press the button "create" ...
    • How do I consult the parts/warehouses list?
      Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
