Requester CMMS - Periodic Synchronization
Periodic
synchronization allows you to set the desired time interval for the
execution of the automatic synchronization of the information logged in the
application. This way, you don't need to use manual synchronization.
To activate periodic
data synchronization, follow these steps:
- Go to Menu | Configurations | Synchronization;
- Active the Sinc.
each option;
- Select the time
interval in which you want the synchronization to take place.
If the application is
running in the background, the automatic periodic synchronization is not
performed.
This feature is not
compatible with iOS.
Mobile – How to set up the Valuekeep Requester CMMS?
The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
How to access the Valuekeep Requester CMMS mobile app?
To access the Valuekeep Requester CMMS, before entering the app, you must accept the request you've been sent. Roles supported on the Valuekeep Requester CMMS app: Root - Administrator Requester - Requester RequestsManager - Requests Manager If you ...
Mobile - How to do Valuekeep CMMS's configuration?
The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
Mobile – How to set up the Valuekeep CMMS?
i. The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
How to access the Valuekeep Technician CMMS mobile app?
To access the Valuekeep Technician CMMS, before entering the app, you must accept the request previously sent. Roles supported on the Valuekeep Technician CMMS app: Root - Administrator Technician - Technician WorkManager - Work Manager
