Request Mobile - How to synchronize?
When the user accesses Valuekeep Requests, he does not have data, to get them it is necessary to synchronize them.
When entering the app for the first time, the data will be automatically synchronized in Background, however, the user can synchronize manually at any time.
To manually synchronize the data, you must access: Menu | Synchronize. The data to be synchronized is divided in 3 areas:
  1. Requests
  2. Assets
  3. Support Tables
Request Synchronization
The request synchronization can be performed by the synchronization menu or by pressing the synchronization icon above the app.
On the synchronization menu, when selecting the Requests option, the following data will be synchronized:
  1. Requests (Upload)
  2. State Transition (Upload)
  3. Requests (includes Follow Up)
Asset synchronization
On the synchronization menu, when selecting the Asset option, the following data will be synchronized:
  1. Locations
  2. Equipment
  3. Tools
If any asset change is detected since the last synchronization, the asset is synchronized.
After the synchronization, the result is presented:
  1. If it is a positive result, it presents the number of assets synchronized for each type.
  2. If it is a negative result, it specifies that there was an error synchronizing.
Synchronization of support tables
On the synchronization menu, when selecting the Support Tables option, the following data will be synchronized:
  1. Deleted Entities
  2. Consents (Upload)
  3. Request States (includes State Transition)
  4. Justifications
  5. Justification Types
  6. Priority Levels
  7. Criticalities
  8. Request Types
  9. Consent
On the synchronization process, you must consider the following:
  1. The synchronization process only returns the reports that were changed.
  2. After the synchronization, the result is presented.
  3. If it is a negative result, it specifies that there was an error synchronizing.
  4. If it is a positive result, it presents the number of data synchronized for each type.
    • Mobile: how to synchronize information?
      When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background.   To synchronize the data, you must ...
    • Request Mobile – How to explore the requests?
       The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. ​Dashboard – allows the ...
    • Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
      On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: Details tab - viewing request/workflow state transitions. Remarks tab - changing remarks. Attachments tab - adding attachments. To ...
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
      On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
