Mobile - How to report consumptions from the requisition?
requisition?
To report
consumptions from the requisition, follow these steps:
Access
Menu | Report Work;
On the
work order list, select the work order you wish to report consumption;
On the
work order options (3 dots icon), click Consumption;
The
list of work order consumption reports will be displayed;
To
create a consumption report, click the icon (+);
On the
consumption report form, fill in the required fields, identified with (*)
and add the part consumptions, by clicking the icon (+);
To add
parts to a requisition, click the option "Requisitions";
The
list of requisition parts associated to a work order is presented;
You
can select each element of the list or select all;
Click
the checkmark to save the consumption report.
It is only possible to create reports if the work order
state allows to record work.
The quantity of requisition parts on the list of
requisition parts associated to the work order is always the same as the
original quantity. The quantity is validated when synchronizing.
A part of the item type must have
the inventory tab, if not, the warehouse is not presented for selection.
It's not possible to report consumptions
for parts without inventory.
Mobile - How do I report, change or delete consumptions?
To report consumptions, follow these steps: Access Menu | Report Work; On the work orders (WO) list, select the WO for which you want to consult/record consumptions; On the work order options (3 dots icon), click on Consumption; The list of ...
Mobile Requests - How to view and track follow-ups?
To access the Request follow-ups, follow these steps: 1. Access Menu | Requests 2. On the request list, select the request for which you wish to view the follow-ups; 3. Access the Follow-up tab on the lower part of the screen. 4. On ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
Custom mobile report – Printing
Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
To report consumptions from the requisition, follow these steps: Access Menu | Report Work; On the work order list, select the work order you wish to report consumption; On the work order options (3 dots icon), click Consumption; The list of work ...
