Mobile Requests – How to explore the requests?
The Requests can be viewed using the following options:
i.Requests List – allows the Requester to view the state Requests you created, as well as view the Requests created on the device and that have not been synchronized yet.
ii.Dashboard – allows the Requester to immediately know the number of Requests assigned to them, broken down by state.
    • Request Mobile – How to explore the requests?
       The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. ​Dashboard – allows the ...
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
    • Mobile Requests - How to view and track follow-ups?
      To access the Request follow-ups, follow these steps: 1.     Access Menu | Requests 2.     On the request list, select the request for which you wish to view the follow-ups; 3.     Access the Follow-up tab on the lower part of the screen. 4.     On ...
    • Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
      On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
    • Mobile – How to explore the requisitions?
      Requisitions can be viewed using the following options: ​ i.Requisitions - On the main Dashboard screen, you can access the option "Requisitions", where all requisitions created by the logged-in user are listed, ordered in decreasing order of request ...
