Mobile Requests – How to explore the Requests?
The Requests can
be viewed using the following options:- Request list – Allows
the requester to view the state Requests you created, as well as view the
Requests created on the device and that have not been synchronized yet.You can
filter this list on several fields, as well as order it, selecting the fields
in ascending and descending order.
- Requester dashboard –
allows the requester to know immediately the number of requests he created and
the state they are in.
Requester dashboard
The dashboard of
requests created by the requester includes:- Synchronization
button;
- Button to
create a new request;
- Button to
access the user request list;
- Button to
scan the Tag.
- In order to directly
create/filter requests with locations/equipment/tools with that Tag associated.
- Graph that
represents the state of the requests created by the user.
Mobile Requests – How to explore the requests?
The Requests can be viewed using the following options: i.Requests List – allows the Requester to view the state Requests you created, as well as view the Requests created on the device and that have not been synchronized yet. ii.Dashboard – allows ...
Request Mobile – How to explore the requests?
The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. Dashboard – allows the ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
Mobile Requests - How to view and track follow-ups?
To access the Request follow-ups, follow these steps: 1. Access Menu | Requests 2. On the request list, select the request for which you wish to view the follow-ups; 3. Access the Follow-up tab on the lower part of the screen. 4. On ...
Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
