Request Mobile - How to set up Valuekeep Requests?
The Valuekeep
Request configuration can be performed using the login screen or using the
application menu (Menu → Configurations).
The configurations
are defined in the following areas:
- Base
configurations
- Language – by
default, the app uses the language selected in the operating system If you wish
to change the language, after selecting the desired language, you must restart
the app.
- Profile
information – on this screen you can find profile information for the user
currently logged in, as well as application and database version data.
- Preferences
- Notify when
finished
- Safety
- Pin – for an
improved data security, the user can create a PIN to access the application, as
well as changing the PIN previously defined. The pin must be a number with 4 to
6 digits.
- Integrated Access – allows to
perform the login inside the app, with the exception of logins in google
accounts.
If
the user has a defined PIN, the PIN is requested when:
- Entering the
application and there is a previously selected subscription;
- Accessing the
selection of the subscription;
- Accessing the
application configurations;
- Removing the PIN
use;
Activating/Deactivating/Changing
PIN.
- To activate the
safety option with PIN, click on the PIN option, define the desired PIN, and
then confirm it.
- To deactivate the
PIN, click the PIN option and enter the current PIN.
- To change the PIN,
click the option Change PIN and enter the current PIN and the new one, and then
confirm it.
The
PIN is only requested after opening the app or changing user, except when
trying to change or remove the PIN.
The
notifications are generated and assigned to the app installed. If there is more
than one user logged-in, you can receive the notification destined for another
user.
Mobile Requests - How to set up Valuekeep requests?
The Valuekeep Request configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: i.Base configurations i.Language – by default, the app uses the ...
Mobile Requests - Error handling
On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
Mobile Requests - How to associate an attachment to a request?
To associate an attachment to a request, follow these steps: i.On the screen for editing or creating a Request, press the "Attachments" tab" ii.On the top right corner, press the "+" symbol. A window with the "Photo" or "Files" options will be ...
Mobile Requests -How to change a request that has already been synchronized to Web CMMS?
On the Requests that have already been synchronized to Web CMMS, it is only possible to perform the following changes: i.Details tab - the request/workflow state transitions. ii.Remarks tab - change remarks. iii.Attachments tab - adding attachments. ...
Request Mobile – How to explore the requests?
The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. Dashboard – allows the ...
