How to report/delete a stock parts issue?
The stock parts issue is always associated to a warehouse, it is
not possible in a single part issue to place several warehouses. To issue a
part, you must access the warehouse tab "Inventory Parts | Warehouses",
select the warehouse you wish to issue stock on.
On
the warehouse tab, in the "Operations" link, select the
"Parts Issues" option;
The
list of parts issues associated with the selected warehouse appears.
Select
the option "Create".
Enter the data. The information to be filled in is organized in
tabs. You can see the required fields using the orange margin or from the list
on the right lower corner, next to the Reset button;
When
a part is automatically removed, a part entry is recorded to readjust the
stock.
It
is not possible to add part entries in externally managed warehouses.
How to record a stock parts entry?
The stock parts entry is always associated to a warehouse, it is not possible in a single stock entry to place several warehouses. To enter a part stock, you must access the warehouse tab "Inventory Parts | Warehouses", select the warehouse you wish ...
How to batch delete spare parts?
To delete spare parts select the option Settings | General | File Import: The import screen is displayed; Select the option Delete Location Spare Parts (if you wish to delete location's spare parts) or Delete Equipment or Tool Spare Parts (if you ...
How to view the current stock for the warehouse parts?
The Parts / Warehouse list allows the maintenance manager to view the existent parts stock in each warehouse. To view the list, select the option "Parts and Inventory | Explore | Parts Stock" or search "Parts Stock". The Parts Stock list has the ...
How to consume spare parts on the work order?
On the asset file (location, equipment or tool), you can specify the parts and the corresponding quantities the asset needs to work correctly. The parts associated to the assets on the section "spare parts" can be consumed on the work order using the ...
How do I consult the parts/warehouses list?
Through the parts/warehouses list, the administrator can look up the relationship between parts and warehouses as defined in the Inventory extension. To look the list up, simply go to Parts and Inventory | Parts and click on Parts/Warehouses. When ...
