How I do remove tasks?
To delete tasks in batches, select the option  Definitions| General | File Import:
  1. The import screen is presented;
  2. Select the option Delete Tasks;
  3. Download the template file to be loaded, on the upper part of the screen and fill in the file;
  4. Then, you must fill in the file according to the rules
    1. The field TaskKey must be defined.
    2. When the import is finished, the import date will be presented that might (or not) contain messages with import details; if an import occurs with no errors/warnings no information on the import details will be presented; if the import records errors/warnings, you can see the errors by clicking on the number of messages.
When filling in the file, you must consider the following points:
  1. The file must always be of the CSV type and the separator character must be ; (semicolon);
You must not remove or add columns to the downloaded template.
    • How do I import tasks?
      The tasks can be inserted from individual records or through batch records by importing .csv files. To load batch assets, select the option Definitions| General | File Import: The import screen is displayed; Select the option Import Tasks; Download ...
    • How to import maintenance plans?
      The maintenance plans can be introduced using individual records or by using batch records, by importing .csv files. To batch load maintenance plans select the option "Definitions| General | File Import": The import screen is presented; Select the ...
    • How to import parts?
      The parts can be inserted from individual records or in batches by importing .csv files.. To batch load parts, follow these steps: Select the Settings| General | File Imports option or access the parts list (Parts and Inventory | Parts) and select ...
    • How do I import parts entry?
      The parts entries in stock can be fed from individual records or through batch records by importing .csv files. To load batch parts entries, select the option Definitions | General | File Import or using the parts entries list ( Parts and Inventory | ...
    • How to import spare parts?
      The spare parts can be inserted from individual records or through batch records by importing .csv files. To batch load spare parts, select the option Settings | General | File Import or using the asset list (Assets | Locations; Assets | Equipment or ...
