What is preventive maintenances batch management?
Preventive maintenances management was designed to allow you to simultaneously change the state, delete or create new versions for a set of preventive maintenances. For that, you must access Work | Preventive Maintenance | Preventive Maintenance Management;
- The preventive maintenance management screen is presented
- Before filtering the data, it is necessary to define the state, this filter is mandatory
- The following filters are optional: workshop, start date, end date and asset;
- Press Apply
- The preventive maintenance list is presented according to the selected filters
- Select the preventive maintenances you wish to perform the same operation to.
The existent options are:
- Change the state
- After selecting the preventive maintenances, on the Operations section, select the option "Change State", on the field State select the state you wish to transition the preventive maintenance.
- Press the button "Process"
- Delete
- After selecting the preventive maintenances, on the Operations section, select the option "Delete"
- New Version
- After selecting the preventive maintenances, on the Operations section, select the option "New Version
- Press the button "Process".
- In the case of the new version, there are the following rules:
- It is only possible to create new versions for preventive maintenances on the Approved state
- The new versions can be created on the Pending or Approved state;
- In the new version of the selected preventive maintenances, you can change the following fields:
- projection end,
- priority level,
- workshop,
- responsible
- work order state.
![](//img.zohostatic.eu/zde/static/images/exclamation.png)
It is only possible to select 25 rows at a time
How to batch create work orders using preventive maintenance events?
The preventive maintenance events were designed to allow to create work orders using each preventive maintenance event. To do this, follow these steps: Access Work | Preventive Maintenance | Preventive Event Management; Filter the data by Preventive ...
How does preventive maintenance rescheduling work?
The preventive maintenance events recalculation is a daily process that recalculates all preventive maintenance events. This recalculation can be done automatically or as requested by the user. To automatically make it available, you must select the ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
How to create a new version of the preventive maintenance?
Creating new versions allows you to improve preventive maintenance by reusing the current configuration. To create a version, access Work | Preventive Maintenances; The list of preventive maintenances will be displayed; Select the preventive ...
What is the workflow of the preventive maintenances?
The preventive workflow has the following states: State Notes New Initial state. Allows changes Approved Does not allow changes. Create the preventive mainentance events. Closed Final state. Does not allow changes. Replaced Final state. Does not ...
