How does preventive maintenance rescheduling work?
The preventive maintenance events recalculation is a daily process
that recalculates all preventive maintenance events. This recalculation can be
done automatically or as requested by the user.
To automatically make it available, you must select the option Definitions
| Work | Background Services and activate the Event Rescheduling.
To calculate it manually, access the Work | Preventive
Maintenances option:
In
the preventive maintenance list, select the preventive maintenance you
want to reschedule;
Select
it and in the link Operations select the operation Reschedule
Events. In the preventive maintenance list, you can add the column Reschedule
Log to see if the rescheduling was successful or not.
If
the preventive has already been successfully recalculated today (depending on
the time zone), it will not be recalculated.
How to create work orders from a preventive maintenance event?
From a preventive maintenance event, you can create a work order automatically or on user request. i.Automatically for the Work Order to be automatically generated on the preventive maintenance file, the state in which the work order is created ...
How to create a preventive maintenance?
Preventive maintenance specifies a set of maintenance actions to be performed based on a fixed recurrence or on meter values. To create a new preventive maintenance, select the option Work | Preventive Maintenances: The list of preventive ...
How to join plans on the preventive maintenance?
When creating a preventive maintenance, it is possible to replace maintenance plans when they occur on the same date or it is possible to join the several maintenance plans in a single work order. When the option “Join Plans” of a preventive ...
How to create a new version of the preventive maintenance?
Creating new versions allows you to improve preventive maintenance by reusing the current configuration. To create a version, access Work | Preventive Maintenances; The list of preventive maintenances will be displayed; Select the preventive ...
How to define a maintenance plan tolerance in a preventive maintenance?
When creating a preventive maintenance, on the tab "Planned Work", you can add a Maintenance Plan and in that plan, you can add the following tolerances: AdvanceTolerance DelayTolerance The tolerance considers the following logic: AdvanceTolerance: ...
