Plugin VK3 - Deployment
Installation of the VALUEKEEP VK3 plugin - Valuekeep Integrator is provided by the Valuekeep Integrator platform, with no additional installation required.
    • How to download the plugin ERP Primavera V10?
      The plugin PRIMAVERA V10 – Valuekeep Integration installation is performed using the PRIMAVERA Deployment Center. This option is only available for customers that have subscribed the module VK.INT – Valuekeep Integrator (see PRIMAVERA Licensing). If ...
    • Plugin PRIMAVERA V10 – Overview
      The PRIMAVERA V10 - Valuekeep Integrator plugin makes integration between PRIMAVERA ERP V10 and other systems possible, namely the Valuekeep solution. This plugin is designed to use the resources of the Valuekeep Integrator platform and the PRIMAVERA ...
    • Plugin V10 - Pipelines – Overview
      The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
    • Plugin V10 – Pipelines – Writer
      The writers provided by the plugin use the resources of the PRIMAVERA V10 API to register (write) the data coming from a source system, meanwhile transformed according to the mapping file defined in the pipeline. The plugin provides the following ...
    • Plugin V10 – Solution – Example
      In the installation folder: <Install Path>, a file (VK3_V10_Integration.config) is provided, which can be reused as a base example when implementing an integration solution. If you want to reuse the example as a potential integration solution, you ...
