Plugin V10 – Solution – Pipelines
An
integration solution is made up of one or several pipelines (integration
flows). The solution made available as a base example has several integration
flows, which can be reused and/or customized according to the business
processes defined.
An integration solution consists of one or several pipelines (integration flows). The solution provided as a base example contains several integration flows, which can be reused and/or customized according to the defined business processes.
Plugin V10 – Solution – Expressions
The use of Expressions when configuring a solution is frequent, due to the high number that a specific expression is applied recurrently. For example, having the solution made available as a base example, all pipelines use the API definition. The ...
Plugin V10 – Solution – Overview
The PRIMAVERA V10 – Valuekeep Integration plugin, offers in its installation folder: <Install Path>\VKPlugin\SAMPLES\CONFIGS, an example of a solution that can be reused as a base example, and that can be customized according to the integration ...
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
Plugin V10 – Pipelines – Auditing
The PRIMAVERA V10 - Valuekeep Integrator plugin conceptually makes available through information categories, using lists, the possibility of monitoring the execution of all pipelines. This functionality allows the implementer / integrator to control ...
