Plugin V10 – Solution – Expressions
The use of Expressions when configuring a solution is frequent, due to the high number that a specific expression is applied recurrently. For example, having the solution made available as a base example, all pipelines use the API definition.
The definition of an Expression is synthesized in the definition of two attributes:
  1. Pattern: identification or designation of the expression with the following syntax “%NAME%”;
  2. Value: set of attributes and corresponding vales that are interpreted by the plugin.
The Connection attribute, present in the expression that defines the API PRIMAVERA V10, is required and must uniquely match the pattern. The passwords must be encrypted using the utility Valuekeep Integrator SDK.
    • Plugin V10 – Solution – Overview
      The PRIMAVERA V10 – Valuekeep Integration plugin, offers in its installation folder: <Install Path>\VKPlugin\SAMPLES\CONFIGS, an example of a solution that can be reused as a base example, and that can be customized according to the integration ...
    • Plugin V10 – Solution – Pipelines
      An integration solution is made up of one or several pipelines (integration flows). The solution made available as a base example has several integration flows, which can be reused and/or customized according to the business processes defined.
      An integration solution consists of one or several pipelines (integration flows). The solution provided as a base example contains several integration flows, which can be reused and/or customized according to the defined business processes.
    • Plugin V10 – Solution – Example
      In the installation folder: <Install Path>, a file (VK3_V10_Integration.config) is provided, which can be reused as a base example when implementing an integration solution. If you want to reuse the example as a potential integration solution, you ...
    • Plugin PRIMAVERA V10 – Overview
      The PRIMAVERA V10 - Valuekeep Integrator plugin makes integration between PRIMAVERA ERP V10 and other systems possible, namely the Valuekeep solution. This plugin is designed to use the resources of the Valuekeep Integrator platform and the PRIMAVERA ...
