Plugin V10 – Pipelines – Writer
The
writers provided by the plugin use the resources of the PRIMAVERA V10 API to
register (write) the data coming from a source system, meanwhile transformed
according to the mapping file defined in the pipeline.
The
plugin provides the following writers that must be used depending on
feasibility and technique applied:
- TableWriter:
used to perform the write operations (insert and update), except for user
entities;
- UserTableWriter: used to perform writing
operations (insert and update) of specific user entities.
Plugin VK3 - Pipelines - Writers
The writers provided by the plugin use the VALUEKEEP V3 API resources to integrate (write) the data coming from a source system into the target system (VALUEKEEP), meanwhile transformed according to the mapping file defined in the pipeline. The ...
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
Plugin V10 – Pipelines – Auditing
The PRIMAVERA V10 - Valuekeep Integrator plugin conceptually makes available through information categories, using lists, the possibility of monitoring the execution of all pipelines. This functionality allows the implementer / integrator to control ...
Plugin V10 – Pipelines – Reader
The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily ...
Plugin V10 – Pipelines – Hashing
The plugin PRIMAVERA V10 – Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been ...
