Plugin V10 – Pipelines – Overview
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
    • Plugin PRIMAVERA V10 – Overview
      The PRIMAVERA V10 - Valuekeep Integrator plugin makes integration between PRIMAVERA ERP V10 and other systems possible, namely the Valuekeep solution. This plugin is designed to use the resources of the Valuekeep Integrator platform and the PRIMAVERA ...
    • Plugin V10 – Pipelines – Auditing
      The PRIMAVERA V10 - Valuekeep Integrator plugin conceptually makes available through information categories, using lists, the possibility of monitoring the execution of all pipelines. This functionality allows the implementer / integrator to control ...
    • Plugin V10 – Pipelines – Reader
      The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily ...
    • Plugin V10 – Pipelines – Hashing
      The plugin PRIMAVERA V10 – Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been ...
    • Plugin V10 – Solution – Pipelines
      An integration solution is made up of one or several pipelines (integration flows). The solution made available as a base example has several integration flows, which can be reused and/or customized according to the business processes defined.
