Plugin V10 – Pipelines – Lists
In the scope of integration, readers use the
resources of the lists in order to define and segment the information
applicable to the business process. As a tool for easy use and monitoring of
business processes, the plugin adopted the application lists as a transversal
reading technique, enhancing the performance of the services.
The plugin provides the following readers that
should be used depending on feasibility and technique applied.
- ListReader: uses a list based on an information
category. The information transmitted is restricted exclusively to that
provided by the list, including the filters applied;
- AdhocListReader: uses a list based on a query,
enhancing integration. The transmitted information is restricted exclusively to
the information provided by the list;
- FullListReader: uses a list based on an
information category. The transmitted information corresponds to a get request
from the entity, that is, the list is only used to get the subset (conditional
filter);
- FullAdhocListReader: uses a list based on a
query, enhancing integration. The transmitted information corresponds to a get
request from the entity, i.e. the list is only used to obtain the subset
(conditional filter).
In order to enhance the performance of the services, the lists should
include conditional filtering based on versioning control (hashing field)
The plugin distributes several sample application lists in: <InstallPath>\VKPlugin\SAMPLES\V10LISTS\PRIMAVERA10_VALUEKEEP3,
which you can explore and use in developing your pipelines.
Plugin V10 – Pipelines – Auditing
The PRIMAVERA V10 - Valuekeep Integrator plugin conceptually makes available through information categories, using lists, the possibility of monitoring the execution of all pipelines. This functionality allows the implementer / integrator to control ...
Plugin V10 – Pipelines – Reader
The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily ...
Plugin V10 – Pipelines – Hashing
The plugin PRIMAVERA V10 – Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been ...
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
Plugin V10 – Solution – Pipelines
An integration solution is made up of one or several pipelines (integration flows). The solution made available as a base example has several integration flows, which can be reused and/or customized according to the business processes defined.
