Plugin V10 – Pipelines – Auditing
The PRIMAVERA V10 - Valuekeep Integrator plugin conceptually makes
available through information categories, using lists, the possibility of
monitoring the execution of all pipelines. This functionality allows the
implementer / integrator to control the execution of integration flows and even
identify anomalous situations that may require changes in the configuration of
flows and/or integration services.
The audit of integration flows (pipelines) is defined in the configuration
of the pipeline, in which you can identify/configure this service. The plugin provides an auditing service:
V10AuditWriter.
- Monitoring is supported through the following
information categories.
- - VKI - Piplines: category of information that
contextualizes the definition of pipelines;
- - VKI - Audit Pipelines: category of information
that contextualizes the execution of pipelines.
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
Plugin V10 – Pipelines – Reader
The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily ...
Plugin V10 – Pipelines – Hashing
The plugin PRIMAVERA V10 – Valuekeep Integration adopts a version control based on a hashing system. Each pipeline has a version control, that is, it has a hashing key that allows to identify if the information subset (hashset) has still not been ...
Plugin V10 – Solution – Pipelines
An integration solution is made up of one or several pipelines (integration flows). The solution made available as a base example has several integration flows, which can be reused and/or customized according to the business processes defined.
An integration solution consists of one or several pipelines (integration flows). The solution provided as a base example contains several integration flows, which can be reused and/or customized according to the defined business processes.
