Plugin PRIMAVERA V10 – Overview
The PRIMAVERA V10 - Valuekeep Integrator plugin makes integration between
PRIMAVERA ERP V10 and other systems possible, namely the Valuekeep solution.
This plugin is designed to use the resources of the Valuekeep Integrator
platform and the PRIMAVERA V10 API.
Besides enhancing the integration capacity between systems, it allows the
implementer and/or integrator to define their integration processes
(scalability), being able to reuse pipelines and functions already developed
(reuse). Monitoring of integration processes is also supported by the plugin,
using PRIMAVERA ERP V10 information categories.
The management and control of the execution of integration pipelines is the
sole responsibility of the Valuekeep Integrator platform.
In order to
enhance the use of this plugin, a solution (example) for integration with the
Valuekeep maintenance system is provided. This solution is available in the
installation folder: <InstallPath> <VKKPlugin\SAMPLES.
Plugin V10 - Pipelines – Overview
The pipelines examples distributed by the plugin PRIMAVERA v10 – Valuekeep Integration, available on – <InstallPath>\VKPlugin\SAMPLES – adopt a configuration based on the methodology Reader-Mapper-Writter, as shown on the following message.
Plugin V10 – Solution – Overview
The PRIMAVERA V10 – Valuekeep Integration plugin, offers in its installation folder: <Install Path>\VKPlugin\SAMPLES\CONFIGS, an example of a solution that can be reused as a base example, and that can be customized according to the integration ...
How to download the plugin ERP Primavera V10?
The plugin PRIMAVERA V10 – Valuekeep Integration installation is performed using the PRIMAVERA Deployment Center. This option is only available for customers that have subscribed the module VK.INT – Valuekeep Integrator (see PRIMAVERA Licensing). If ...
Plugin V10 – Pipelines – Writer
The writers provided by the plugin use the resources of the PRIMAVERA V10 API to register (write) the data coming from a source system, meanwhile transformed according to the mapping file defined in the pipeline. The plugin provides the following ...
Plugin V10 – Pipelines – Reader
The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily ...
