Mobile - How does the synchronization work?
Mobile: how to synchronize information?
When the user accesses Valuekeep CMMS, he does not have data, to get them it is necessary to synchronize them. When entering the app for the first time, the data will be automatically synchronized in Background.
 To synchronize the data, you must access: Menu → Synchronize. The data to be synchronized is divided in 3 areas:
i.Work
ii.Assets
iii.Support Tables
Work Synchronization
The work order synchronization can be performed by the synchronization menu or by pressing the synchronization icon above the app.
On the synchronization menu, when selecting the Work option, the following data will be synchronized:
i.Work orders
ii.State transitions
iii.Labor report
iv.Consumption report
v.Other costs report
vi.Task verification report
vii.Downtimes
viii.Failures
ix.Meter values
x.Monitoring values
xi.Consent
Asset synchronization
On the synchronization menu, when selecting the Asset option, the following data will be synchronized:
i.Locations
ii.Equipment
iii.Tools
iv.Routes
For each option, the corresponding access levels are downloaded.
If any asset change is detected since the last synchronization, the asset is synchronized.
After the synchronization, the result is presented:
  1. If it is a positive result, it presents the number of assets synchronized for each type.
  2. If it is a negative result, it specifies that there was an error synchronizing.
Synchronization of support tables
On the synchronization menu, when selecting the Support Tables option, the following data will be synchronized:
i.Workshop
ii.Unit
iii.Parts
iv.Priority levels
v.Work order types
vi.Operating states
vii.Entity states
viii.Justification
ix.Justification Types
x.Employees
xi.Maintenance plans
xii.Task verification
xiii.Misc Costs
xiv.Misc Cost Types
xv.Currency
xvi.Scheduling Labor Costs
xvii.Failure Type
xviii.Meters
xix.Monitorings
xx.Access levels
xxi.Criticalities
xxii.Brands
xxiii.Models
xxiv.Asset Families
xxv.Requisition Types
xxvi.Mobile Report
On the synchronization process, you must consider the following:
i.The synchronization process only returns the reports that were changed.
ii.After the synchronization, the result is presented.
iii.If it is a negative result, it specifies that there was an error synchronizing.
iv.If it is a positive result, it presents the number of data synchronized for each type.
    • Mobile - How to explore work orders?
      It is very important for technicians to be able to quickly view the work that they must perform. You can check the work that needs to be done through the following options: Technician dashboard – allows technicians to immediately know the number of ...
    • Mobile - How do I print a work order report?
      The technicians can print the work order report with or without the signature when ending or during the execution. To print a work order report, it is necessary to access the detail window of the workorder. The access to this detail is performed ...
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
    • Custom mobile report – Printing
      Technicians can have a custom report to print the work order information. For that, you must create a report with the desired structure and export the file (.txt) generated for the BackOffice on the option "Mobile Reports". After accessing the work ...
    • Mobile - How to do Valuekeep CMMS's configuration?
      The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu -> Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the ...
