Mobile Requests - How to set up Valuekeep requests?
The Valuekeep Request configuration can be performed using the login screen or using the application menu (Menu → Configurations).
The configurations are defined in the following areas:
i.Base configurations
i.Language – by default, the app uses the language selected in the operating system If you wish to change the language, after selecting the desired language, you must restart the app.
ii.Profile information – on this screen you can find profile information for the user currently logged in, as well as application and database version data.
iii.Consent
i.Push Notifications – to receive push notifications, the user needs to consent to the collection.
ii.Preferences
i.Synchronization
i. Notify when finished
ii.Safety
i.Pin – for an improved data security, the user can create a PIN to access the application, as well as changing the PIN previously defined. The pin must be a number with 4 to 6 digits.
    • If the user has a defined PIN, the PIN is requested when:
i.Entering the application and there is a previously selected subscription;
ii.Accessing the selection of the subscription;
iii.Accessing the application configurations;
iv.Removing the PIN use;
    • Activating/Deactivating/Changing PIN.
i.To activate the safety option with PIN, click on the PIN option, define the desired PIN, and then confirm it.
ii.To deactivate the PIN, click the PIN option and enter the current PIN.
iii.To change the PIN, click the option Change PIN and enter the current PIN and the new one, and then confirm it.
The PIN is only requested after opening the app or changing user, except when trying to change or remove the PIN.
The notifications are generated and assigned to the app installed. If there is more than one user logged-in, you can receive the notification destined for another user.
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
    • Mobile – How to set up the Valuekeep CMMS?
      i. The Valuekeep CMMS configuration can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations  Language – by default, the app uses the ...
    • Mobile Requests – How to explore the requests?
      The Requests can be viewed using the following options: ​ i.Requests List – allows the Requester to view the state Requests you created, as well as view the Requests created on the device and that have not been synchronized yet. ii.Dashboard – allows ...
    • Mobile Requests - How to associate an attachment to a request?
      To associate an attachment to a request, follow these steps: ​ i.On the screen for editing or creating a Request, press the "Attachments" tab" ii.On the top right corner, press the "+" symbol. A window with the "Photo" or "Files" options will be ...
    • Mobile – How to set up the Valuekeep Requester CMMS?
      The Valuekeep CMMS can be performed using the login screen or using the application menu (Menu → Configurations). The configurations are defined in the following areas: Base configurations Language – by default, the app uses the language selected in ...
