Mobile – How to explore the requisitions?
Requisitions can be viewed using the following options:
i.Requisitions - On the main Dashboard screen, you can access the option "Requisitions", where all requisitions created by the logged-in user are listed, ordered in decreasing order of request date.
ii.Requisitions by Work Order - Access the option "Report Work", enter the Work Order and, on the upper right corner, click on the 3 dots button ("..."), and the option Requisitions will be presented. In that option, all Requisitions associated to the selected Work Order will be presented.
    • Mobile Requests – How to explore the requests?
      The Requests can be viewed using the following options: ​ i.Requests List – allows the Requester to view the state Requests you created, as well as view the Requests created on the device and that have not been synchronized yet. ii.Dashboard – allows ...
    • Request Mobile – How to explore the requests?
       The Requests can be viewed using the following options: Request list – allows the requester to view the state of Requests he created, as well as view the Requests created on the device and that have not been synchronized yet. ​Dashboard – allows the ...
    • Mobile Requests - Error handling
      On the Mobile Requests app, it is possible to handle errors and check the errors that occurred during the synchronization. To see the error list, you must access the menu and select the option Synchronize. On that screen, you can see the errors by ...
    • Mobile - How to record/change/delete requisitions?
      Table of contents To create a Requisition, follow these steps: 1.     Access the "Requisitions" option; 2.     The requisition list is presented: 1.     Synchronized reports - these only allow to view, you cannot change them; 2.     New reports ...
    • Mobile Requests - How to view and track follow-ups?
      To access the Request follow-ups, follow these steps: 1.     Access Menu | Requests 2.     On the request list, select the request for which you wish to view the follow-ups; 3.     Access the Follow-up tab on the lower part of the screen. 4.     On ...
